98 torque convertor not staying locked up
Old May 4, 2013 | 02:11 PM
robert78.5's Avatar
98 torque convertor not staying locked up, neighbours truck is acting up, what can it be?
Old May 4, 2013 | 03:53 PM
j-fox's Avatar
Plenty of reading if you search it.
12 valve or 24 valve?
12 valve sometimes is the tps.
24 valve is noise in the electrical system.
Old May 5, 2013 | 05:27 PM
Rogan's Avatar
As j-fox stated, it depends on what year truck you're working with, as to what the root of the problem can be.
Here's a couple quick tests (94-01)...
  1. Start the truck, take a DVM (Digital volt meter), set it to DCV, and measure across the battery. should be 12-14VDC..
  2. Now set the DVM to VAC, and measure across the battery, again, as before. VAC side should show less than 0.100 volts. Anything higher than that, and the alternator is causing RF induction, or AC voltage waveform.
You can use a BD RF filter to band-aid the problem. Or, you can fix the source: The alternator.
If your trans kicks in/out consistantly, try test to for verification (note*: Best to do this in daylight hours, as you'll not be recharging the batteries during this test) :
  1. Remove the alternator fuse from the PDC, and test drive it. See if the trans stops doing the in/out crap. It most likely will.
  2. If trans acts as it should, then the noise is being induced by the alternator.
  3. Re-install the fuse. If the trans goes back to acting ignorant, you've now further enforced the issue.
VaultRam
Jun 1, 2014 04:52 PM
Otis
27
Feb 17, 2012 05:18 PM
93dieselZak
Jun 16, 2011 06:10 PM
welndmn
Oct 9, 2006 05:55 PM
mppd20
Dec 17, 2004 07:02 PM
