98 12V Auto TST 605/230
Old Apr 28, 2020 | 12:11 PM
disco's Avatar
Was pulling my 3500# boat up the launch ramp. In 2wd it spun the wheels so I shifted to 4wd high. Engine reved up pyro came up to 900 but truck wouldn't move. Only way I could move it was by shifting to 4wd low. Meanwhile gauges were going nuts on and off and the tach completely stopped registering anything. Back on level ground I went back to 2wd high and pulled the boat home like normal except for the instruments and check engine light continuing to go nuts, still no tach. Disconnected batteries pulled and cleaned plugs on trans control unit reconnected everything. Truck seems to drive normal (haven't tried to pull the boat yet). When I start it the tach comes up but immediately drops back to zero (all other instrument work). Ideas?
Old Apr 28, 2020 | 12:58 PM
AlpineRAM's Avatar
Sounds like the crank position sensor on the front of the engine to me.
Without the signal the tach, charging, AC will not work.
Old Apr 28, 2020 | 01:02 PM
disco's Avatar
OK thanks. Is there a way to test it? Do I need a code reader?
Old Apr 28, 2020 | 02:03 PM
disco's Avatar
I believe you nailed it. No AC, charging or tach. I'll readjust and if that doesn't fix it, install new. Thanks!
Southtowns27
20
Jun 26, 2011 09:36 AM
92smokin blacky
Sep 26, 2009 10:27 PM
Lundee
Feb 17, 2008 11:05 PM
Chrisf
Aug 21, 2006 07:28 PM
thedblc
May 30, 2006 06:31 PM
