97 fuel problem?
Old Sep 29, 2010 | 10:56 AM
ardpms's Avatar
97 fuel problem?
i have a 97 2500 12v and after it sits for 6-8 hrs i stumbles on take off, like it doesnt have enuf fuel after running 1/4 mile or so it is fine any suggestions?
Old Sep 29, 2010 | 12:27 PM
macattack_ga's Avatar
sounds like air in the fuel...
Old Sep 29, 2010 | 06:26 PM
infidel's Avatar
Could be your idle or fuel pressure is too low.
Instructions> http://www.cumminsforum.com/forum/94...-12-valve.html
and> http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
An air leak almost always causes hard starting.
Old Sep 29, 2010 | 09:44 PM
chariotdriver's Avatar
Does it still have the fuel heater? If so, jettison the POS. It is pretty much worthless and only causes problems when it (or its seals) start to go out. It injects air into the fuel stream on the suction side. Usually it causes starting problems because it lets the fuel in the suction line drain back into the tank. Let us know what you come up with, cd
Old Oct 2, 2010 | 09:34 PM
ardpms's Avatar
fuel
none of the seals seem bad i dont know what fuel pressure is no gage yet
CTD23
Jun 9, 2006 09:32 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
