96 rearend ?
Old Feb 13, 2007 | 09:00 AM
gwhammy's Avatar
96 rearend ?
Just a quickie, 96 automatic four wheel drive does it have a dana 70 or dana80 rearend? Thanks
Old Feb 13, 2007 | 09:03 AM
Crimedog's Avatar
Should be a 70. You can double check just in case on the axle housing itself. The number should be cast into one of the gussets at the differential.
Old Feb 13, 2007 | 09:21 AM
gwhammy's Avatar
I was pretty sure on a 2500 it should be a 70 but not positive. The truck's not here right now plus there's 6+ inches of new snow on the ground so crawling under it is not an option today. Thanks
Old Feb 13, 2007 | 09:22 AM
frostytj's Avatar
I copied the following from a previous post I had made.
I believe the auto's have the dana 70 and manual's have the dana 80. Not sure on the duallys, but I assume all are D80s. Mine is also stamped on 2 sides of the housing.
Also if you find the BOM you can plug it into http://www2.dana.com/expertforms/demenu.aspx under Light Axle and then Build of Material. That will tell you what axle it is. BOM can typically be found here as well as model number. This is a front axle so it might be a bit different for the rear.
Old Feb 13, 2007 | 09:38 AM
TxDiesel007's Avatar
Mine has a Dana 80
IIRC the Dana 80 came with the manual transmission trucks..
Rick
abb
Sep 13, 2003 01:13 PM
Pontiac puller
Sep 10, 2003 08:51 AM
sshelly
Jun 23, 2003 11:34 PM
big b
Nov 10, 2002 03:50 PM
ronster
Nov 1, 2002 04:14 AM
