95 auto trouble?
Old Jun 21, 2004 | 11:50 AM
INJECTOR JACK's Avatar
Question 95 auto trouble?
A guy at work has a 95 12v with a auto trans, He is saying when he 1st fires the truck it will not move till it sit's and runs for a while then it drives fine after that. The tranny has been replaced and the torque has been replaced 2 times. Does any body out there know about or have had this problem? Any help would be great!
Old Jun 21, 2004 | 12:15 PM
Smokee's Avatar
The problem is likely flow back. He should put it in neutral for a minute or so. There is supposed to be a valve on the cooler line...I forget where right now. Someone will jump in.
Old Jun 21, 2004 | 01:51 PM
infidel's Avatar
'95s had a recall to install a check ball (anti-flow back) Either the recall wasn't done or the check ball was removed. Many folks remove them to eliminate any restriction to the cooler. I don't have the ball in mine and just live with the slow time to fill the TC. Any warm ups should be done in N to speed fill up.
Old Jun 21, 2004 | 02:07 PM
Talking 95 auto trouble
Thank's for the info guy's I will pass it on to him.
Old Jun 21, 2004 | 08:00 PM
Dufrain's Avatar
Mine did that a couple times when I first got it so I just leave mine in N and step on the parking brake,i never put it in park and it never drains back that I can tell.I start it up watch the oil pressure guage go over and take off no problem.
Old Jun 26, 2004 | 05:01 PM
cumminsdriver635's Avatar
Just tell him to let it idle in neutral for a second, and that circulates the fluid, and should pretty much eleminate the problem.
Eric
ridlangus123
Dec 30, 2013 08:36 PM
Shootist
Jul 11, 2008 08:23 PM
frog
Aug 14, 2006 01:45 PM
betsycam
Jul 25, 2006 07:17 AM
moss2904
Jan 3, 2003 03:27 AM
