95 auto trans ?
Old Jan 22, 2010 | 01:44 PM
newdad's Avatar
95 auto trans ?
im in the middle of a 95 engine and trans swap in my 90 1st gen. is there anything besides the od and lockup that the pcm controls? i think that is all that is controlled but i just wanna make sure. another ? is can i use a driveshaft out of a 2wd reg cab lwb '94 to '98? thanks in advance for the replies.
Old Jan 22, 2010 | 03:08 PM
newdad's Avatar
anybody?
Old Jan 24, 2010 | 11:57 AM
Carl's Avatar
The 94 and 95 are the only two years that the 47RH trans was put in the dodge diesels. OD and Tq Lock are the only two things your have to worry about. I use a taggo switch to control my OD and Tq Lock. I have First gen 12 v with 95 47RH behind 241D transfer case.
Old Jan 24, 2010 | 12:01 PM
Carl's Avatar
You should be able to use the drive shaft, but may need to be cut down or lenghten it depending on long or short bed. try to get a extra long one, shorting is a hole lot cheeper.
DodgeDiesel61
Jun 3, 2008 07:50 PM
lews930
Mar 7, 2007 06:33 PM
spitfire9137
Mar 10, 2006 06:29 AM
ezdemon72
14
Jul 29, 2005 10:05 AM
ckennedy
Sep 27, 2004 11:58 AM
