94 ctd- common problems??
Old Dec 4, 2004 | 12:17 AM
banks twinram's Avatar
ok. thanks a lot man. really appreciate it. this site is full of good people with valuable information!
Old Dec 5, 2004 | 05:41 PM
mx261's Avatar
OK back to Rhino,s inquiry. Ill post this again here. I replaced my fuel lines from the motor to the stell lines. I bought 3/8 and 5/16. I coundnt find deisel rated stuff so I bought reg rienforced gas line. The 3/8 seemed too big as it would pull right off both lines with ease so we went with 5/16 on both. the truck started very good for about 3 or 4 days. then back to starting hard. with white smoke and a miss for a few minutes. Lately i havent been filling the tank because im am lyed off and cash is tight for xmas. anyway though it SEEMS to start better towards half tank but cant be 100% of this. I am looking into checking the pick up in the tank as well as running rubber all the way to tank but like i said before I cant seem to get deisel rated here and all the shops and mechanics get a kick out of it, telling me to just run gas line. I was going to get the kit off of fosters but again the line size was a factor. Now im slow to working on this thing as my "shop " consists of a 12 by 20 concrete slab out in the elements. I currently do not have anywhere to do this inside so that plays a factor on how fast this gets done. Gotta love cold concrete!!
Old Dec 5, 2004 | 06:27 PM
Rhino's Avatar
I would first start with checking your fuel pressure. Low fuel pressure can cause a hard start. Not to mention it is a good thing to do anyway.
White smoke and a miss is usually a good indication of slipped timing. Timing would be the next thing I would check.
What is your idle at? If your idle is a touch low it will cuase the truck to start a little harder too.
Old Dec 5, 2004 | 07:20 PM
mx261's Avatar
idles around id say 750 maybe
Old Dec 5, 2004 | 07:31 PM
Rhino's Avatar
750 is a bit low. You might try bumping the idle a bit. If you rest your foot on the throttle a bit when cranking does it start easier?
Old Dec 5, 2004 | 07:53 PM
mx261's Avatar
yeah when it doesnt start, on the 2nd try i floor it and it starts, if i dont touch the pedal it wont start, aslo i dont know how to adjust the idle
Old Dec 5, 2004 | 08:37 PM
ride_a_hd's Avatar
http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
Try this site.
Old Dec 5, 2004 | 08:42 PM
Rhino's Avatar
If you have to floor it to get it to start adjusting the idle probably won't help much. If you just have to give it a little bump on the pedal to get it to fire up then an idle adjustment would help.
Old Dec 5, 2004 | 10:33 PM
96_12V's Avatar
You should not need to floor it. On my drivers side visior it literally states that the cold start procedure (under 40F) is the "rest" your foot on the throttle, about 1/4 of the way down at the most. If I do this the crank time is under 1/2 second. If I do not, it's about 2sec but never fails to start and very little smoke. This is for both cold and warm starting, on mine it makes little differance.
I worked with a Case 1845C this summer in Wisconsin (3.9L B-series four, no turbo) that when fully warmed up and shut down for more than one minuite would not re-start. Just cranked. If it sat for 1/2 hour, it would re-start. Only thing I could determine was a small pinehole leak allowing air to bleed in or fuel to bleed away from the injectors upon shutdown to allow the engine to airlock.
Old Dec 5, 2004 | 10:37 PM
mx261's Avatar
yeah its weird, but if i dont floor it, it wont start. Ive tried both ways. Im in the process of replacing the fuel lines all the way to the tank but havent gotten a concrete answer on whether or not reinforced gas line will work as I cant find any deisel rated hose around here. The only place that had it told me it was 8 bucks a foot
Old Dec 7, 2004 | 07:25 PM
mx261's Avatar
ok I am going to try a marine boat shop for fuel line. That may work out. cpl ? though. If all im doing is driving the truck- hardly any towing of any kind then my egts with the plate slid foward shouldnt be a problem TILL i get gauges correct?? Also what is the average cost of having your pump timing checked or changed?
Monty
48
Sep 20, 2022 06:33 AM
Monty
30
Oct 2, 2012 11:47 AM
Flatty
22
Dec 13, 2004 03:09 PM
Idaho Guy
13
Nov 29, 2004 02:20 PM
