94 4 wheel drive engagment
Old 12-31-2005, 11:45 PM
West Coast's Avatar
When engaging the 4 HI on a 4 x 4 5 speed do you 5 speed guys stick the clutch in? Or just ease the transfer case in while in gear??? Sometimes mine engages smooth, other times a little rough. I always put the clutch in.... Maybe clutch in is not correct????
Happy New Year.....!!!
Dave
Old 01-01-2006, 04:05 AM
P.O.R.'s Avatar
i push the clutch in,then pull it into 4x4,then ease the cluch out,this is how i do it with the truck rolling or not,works fine for me...
Old 01-01-2006, 10:55 AM
TxDiesel007's Avatar
Dave
Happy New year Dave!
When i engage my 4wd, i do use the clutch as well..
Tx
Old 01-01-2006, 11:02 AM
Dshiftff's Avatar
Ive never held in the clutch while engaging, Maybe Ill try it next time to see if it goes smoother...
Old 01-01-2006, 11:26 PM
West Coast's Avatar
clunk??
I have noticed that last few times I take it out of 4 wheel high it makes a cluck about 1 mile after the 4wd light goes out. Sound like one of the hubs is still locked for few minutes???? Any thoughts.....??? I just replace my 4 wheel drive axle. New transer case oil. And new SB clutch.....
Dave
Old 01-02-2006, 12:08 AM
NHDiesel's Avatar
You don't need to use the clutch. The t-case is always spinning because its attached to the rear axle by the driveshaft, so using the clutch does nothing. Just let off the throttle so you are coasting (not under power, or compression braking...just coasting) and pull it in. Also only engage while moving if you are going straight, not in a corner if you can help it, and don't ever engage 4x4 if the rear tires are spinning on a slippery road. Thats another reason to let off the throttle.
The clunk is the front axle disconnect disengaging. You don't have hubs, only the 1 disconnect. If there is enough friction there, it may take a while to unlock. It shouldn't be much of a clunk, just a bit of a click.
Jim
Old 01-03-2006, 09:56 PM
74dart's Avatar
Truck Jumps
I have a 96 with auto trans. I know the manual says you can shift in and out of 4 wheel high at speeds up to 50 mph. If I do that the front axle does not imeadetly disengage and when it does it makes the whole truck jump. To solve this problem I shift out of 4 wheel I drive in reverse a few feet like the old auto locking hubs. Just thought I'd put in my two cents.
L.J.B.
06-27-2014 10:21 AM
elkhide
02-13-2012 04:50 PM
04ctd
12-07-2007 08:19 PM
gman2310
09-27-2006 12:08 AM
Teddy
11-02-2002 01:56 AM
Quick Reply: 94 4 wheel drive engagment
