6 speed into 96 auto
Old Nov 5, 2007 | 01:39 AM
rmk4x4's Avatar
found me a 6 speed for a 4wd that i am thinking of swaping into my truck auto blew up on me the other night my 3rd one so i have these ?s
fly wheel what to get?
and wireing to make it all work right?
i would have to change my tcase to a 29 spline? were do i get that input shaft?
the rest of of it i think would just be finding parts at the junk yard not too hard and some driveline work thanks for the input
Old Nov 5, 2007 | 12:13 PM
gmctd's Avatar
SB Clutch has the proper clutch disk for early or late NV5600, fits '94-'01 flywheel -
just ask for NV4500 1.250" or NV5600 1.375" splines
get new clutch plate while you're in there
Or, they have complete flywheel\disk\plate package for ~750bucks
get tc input gear for NV4500, replace your chain while you're in the tc
extend tc\backup wiring to fit
get correct length '01\'02 driveshafts from boneyard - rear just needs the short intermediate section between tc and support bearing.
get '98-up crossmember to fit the longer NV5600
Where are you located?
Old Nov 5, 2007 | 02:02 PM
rmk4x4's Avatar
thanks for all the good info going to try to round up the rest of the parts today
will the clutch pedel and stuff out of a gas maunual work for me?
i am in palmer Alaska thanks agin
Old Nov 5, 2007 | 03:28 PM
rmk4x4's Avatar
i am gathering parts today
for the inside i need the clutch pedel and brake assambly and cyninder for the clutch and what eles am i missing? going to be ordering it from a junk yard down south.
got the clutch and flywheel and tcase taken care of going to just fab up a transmisson mount and crossmember going to have my drive shafts rebuilt
going to just leave my auto steering in the truck if i can? and take the shifter off and leave the dash and cover up the auto stuff
Old Nov 5, 2007 | 10:20 PM
gmctd's Avatar
The gasser (patooie!) pedal and stuff should work if it's hydraulic clutch, also - otherwise get the Diesel pedal, linkage rod, master cylinder\tubing\slave cylinder\rod - you can leave the auto steering column in place, just lose the linkage rod.
Old Nov 6, 2007 | 04:27 AM
killed300ex's Avatar
I am doing to swap now wiht a 5 spd The best place for the transfer case input shaft is www.transfercaseexpress.com call them they were more than helpfull. You are looking for the 29 long think they quoted me 125 for a new shaft.
Evan
Old Nov 6, 2007 | 09:53 PM
rmk4x4's Avatar
thanks will give them a try they wanted alot for them here. well i am putting my auto back in tonight after a rebuild had the parts no money in it so it is not down while waiting for parts for this swap cant wait to have 6 speed in it. will make pulling alot more fun
12V_shooter25
Jun 10, 2013 11:22 PM
olskooldodge
Jul 15, 2009 11:13 AM
haftrek
Nov 12, 2007 09:19 AM
emailrick1
Sep 28, 2007 12:52 AM
ckennedy
Sep 27, 2004 11:58 AM
