5sp tranny grinds
Old Oct 16, 2003 | 03:40 PM
shrtmntdiesel's Avatar
5sp tranny grinds
when I change from 2nd to 3rd it wants to grind a little, and down shifting from 3rd to 2nd is dang near impossible > >. Also going into reverse it wants to grind. Do I need to look at replacing :'( the tranny, or is there a fix for this. I forgot it grinds going from 1st to 2nd I don't use this to often so I bout forgot. Thanks guys.
Old Oct 16, 2003 | 03:52 PM
MnTom's Avatar
Re:5sp tranny grinds
Sounds alot like you need new syncros. You will have to pull the tranny to install them. The other choice is to replace the tranny but I would think that that would be expensive.
Tom
Old Oct 16, 2003 | 04:03 PM
Thats kinda what I had thought. Any ideas on what they might cost.
Old Oct 17, 2003 | 12:07 AM
dsljunkie's Avatar
My dad had a new set of sincs installed for about 200 bucks. He had the same thing goin on in his truck . I found out a way "avoid this grind" ... if you can follow this... When you roll up to a stop sign, corner, etc. and come to almost a complete stop you can apply pressure on your brakes and as you let your brakes loose and you get that little "hop" (like when an old lady sticks her foot into the peddle and doesnt let off untill shes good'n stopped )... you know the hop Im talkin about? any how just when you get that little hop you can swiftly shift into second without grinding (if completed successfully )
I dont know if you can figure out my instructs... but I think you definately need a new set of sincs .
Scott
Old Oct 25, 2003 | 11:29 PM
2manydogs's Avatar
My first post on this forum! Usually a grind going into reverse means the input shaft has not stopped turning. Reverse is a non-synchro gear. Try putting it in rev. with the the engine off, e-brake off. Start the truck and notice for a slight movement of the vehicle as soon as you hit the key. It sounds like your clutch might not be disengaging all the way. Jim
22
Jul 12, 2007 09:11 PM
roberts11260
Jul 13, 2006 08:52 AM
Jdonoghue
Jul 6, 2005 10:07 AM
nauitque21
Jun 18, 2005 02:48 PM
nicholashang87
Dec 1, 2004 11:25 PM
