4x4 problems need help
Old Jul 14, 2005 | 11:32 AM
vssman's Avatar
An open diff will have opposite spinning wheels it the drive shaft is held in place. The posi-lock is basically a cable operated version of the vac motor. You can make your own if you wanted to make sure it would work prior to spending cash on a "pretty" unit. To me, it sounds like there may be a little wear on the collar causing it to "hang" when moving to the lock position. It should slide smoothly but not have lots of play.
DJ Turbo.
Oct 13, 2011 09:11 PM
don60
Sep 18, 2010 11:32 AM
dznutz24
Sep 2, 2008 12:15 PM
bsj21
Dec 7, 2007 04:23 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
