4x4
I suspect that you will get varying opinions on this. Personally I don't but I will try to lay out the pros and cons of using 4X4.
Pros: Less likely to lock up one or two tires under braking, rear end won't walk out under acceleration, steering is easier(front wheels pull the truck around).
Cons: Requires that all tires are the truly the same size, wears out some components faster, you are more likely to go somewhere that you shouldn't.
If you were racing, it would be obvious to use 4 wheel drive but just driving along, it is personal preference.
i would put it in 2wd on the highway for only a 1/2 of slush, but last night when it was snowing and it was blizzard like conditions with 4-5 inches of snow on the ground i was in 4wd cranking down the highway at 55, but i also launch in 4wd when im racing someone and i don't take it out until im done with the quarter mile, and it works good.
Be very conservative using 4WD especially being this is your first experience.
Very true
Here's another good rule. 4WD will put you in the ditch twice as fast or twice as far as 2WD on ice.
Cons: ..., you are more likely to go somewhere that you shouldn't.
I think it's personal choice but...... there is absolutely no point in engaging 4X4 AFTER you have been involved in the accident , spun out or hit the ditch. When ditching it sometimes pays to keep the power on and drive your way out and you can't do that in 2WD
catnfool
Dec 31, 2006 11:35 PM
Ridgetop
Jan 26, 2006 02:18 PM
