47RH , no highgear or lockup
Old Jun 15, 2009 | 08:16 AM
John Faughn's Avatar
Got into truck this morning , when I got on highway , I noticed that it did not shift into high gear or lockup , I do have a added lock up switch , no response to switching .
Pulled over at coffee shop , checked fluid , looks good [ color & level ] .
I was thinking , possibly the governor ?
So shooting for ideas .
Thanks
Old Jun 15, 2009 | 10:28 AM
Got back in truck & drove , its working again , which reminds me , I have had some other rare issues , like the warning lites not going off after running , so what I have found is that after either high millage or hanging to much off ignition key [ wearing out the lock/switch ] , that when this happens , the electrical connection in the sw. loses contact .
Old Jun 19, 2009 | 02:17 AM
94ram's Avatar
or it could be your crank positioning sensor.
happened to me and it was very pricey, $1000 total.
i had the same symptoms and my tachometer would shoot all over the place
Old Jun 19, 2009 | 07:51 AM
No tach issues , it is a symptom I have noticed several times with different aspects of the truck , some have been that the warning lites on dash would not got out after starting , wiggling the key would make them go out , so another dodge part outlasted by the Cummins .
Old Jun 19, 2009 | 08:41 PM
mysterystench's Avatar
Maybe check your grounds?
When i was having the same problems, this was the first place I was told to check...
Old Jun 20, 2009 | 02:49 AM
dieselman2300's Avatar
I dont want to burst your bubble, but a crank positioning sensor is around a $100 and is just one bolt and a plug right on the harmonic balancer. It took me less than a half hour to change it and that was getting out the tools, installing, and cleaning tools and putting everything away.
kensmachine
Jul 15, 2010 02:46 PM
kawi600
Dec 22, 2009 01:37 PM
archer39
Sep 22, 2009 08:35 PM
jeffF250Crew
Sep 12, 2009 11:36 PM
Mr. Jimmy
23
Nov 6, 2005 05:13 PM
