47re...similar transmission to what
Old Jan 1, 2008 | 12:35 PM
12ValverDave's Avatar
The reason I ask is im looking for a good overhaul manual for the 47re and i can seem to find anything. I find a lot of the other chrysler transmission manuals, just not the 47re. I have a factory sevice manual and it seems to go through more diagnostics then teardown/overhaul. Is the FSM the best manual or have you found other manuals to work from too?
Thanks,
Dave
Old Jan 1, 2008 | 12:55 PM
robert78.5's Avatar
I have a pretty decent one on adobe file, I can see if I can send you the pages you need. send me your email address.to robcat@mts.net
Old Jan 1, 2008 | 02:02 PM
j-fox's Avatar
Yes the factory service manual is without a doubt the best info. Very complete.
Of course there are things that could be added to make the 47re more durable/dependable.
Old Jan 1, 2008 | 03:14 PM
Sidewinder's Avatar
From what I understand the 47RH and the 47RE are both based on the 727 tranny. The main difference is the addition of the OD unit. The manuals should br similar.
Old Jan 1, 2008 | 04:49 PM
gmctd's Avatar
The RH has a mechanical governor, the RE is computer controlled pressure, the late 48RE's are computer controlled - other than that, the valve body is different, with solenoids, but the mechanical internals are near identical - use the 48RE stuff in the 47's for increased strength - the A500\518\618 pretty much covers it
mr T
Apr 22, 2005 04:55 PM
HorseHauler
18
Oct 22, 2004 04:14 AM
NJMurvin
Mar 6, 2004 08:14 PM
BigBlue
Jul 17, 2003 12:56 PM
Synchiropus
Mar 14, 2003 01:44 PM
