Are 4 bad Starters Possible ?
Old Jul 15, 2013 | 05:46 PM
LanceD's Avatar
I had some starting issues also. Mine would crank slow usually so I bought new batteries. That didn't fix the problem and finally one day I went to start it and it went "click". The lights inside dimmed a ton like the batteries were dead. So I had someone try to jump start me and it still wouldn't start. I ended up connecting the jumper cables directly to the starter and it finally started.
When I got it home, I used my jumper cables to try to isolate bad wires by connecting it from the starter terminal to the battery. Tried to start it and nothing. Then I connected them from the frame to the engine block and it fired right up. Turns out my large ground cables between the engine and frame were worn and no good. Replaced those and have been great since.
Old Jul 16, 2013 | 06:03 PM
infidel's Avatar
I think you can rebuild them yourself, as there might be a sticky somewhere on how to do so
Excellent video> Completely Rebuilding Your Starter
The Domie
Jan 24, 2005 06:08 PM
LanceD
Dec 18, 2004 09:45 AM
wheelin66
Nov 14, 2004 10:31 AM
newf
21
Aug 15, 2004 09:32 PM
dieselnewbie
13
Mar 19, 2004 10:08 PM
