?? for those with remote starters
Old Dec 16, 2004 | 06:51 PM
LanceD's Avatar
I have a python alarm with remote start, and when its cold, it will start and run for a bit and then shut off when the grid heater kicks on. I tried changing it from voltage sensing to tach sensing, and it still does it. I am thinking because the voltage goes down so much with the grid heater turning on that the python thinks something is wrong and shuts it off. thoughts?
Old Dec 16, 2004 | 07:07 PM
Rganser's Avatar
My truck stalls in the morning unless i BARELY touch the pedal for the first 30 sec.
Ryan
Old Dec 16, 2004 | 08:14 PM
LanceD's Avatar
mine did too, so I bumped the idle up to 800-900 or so. but I am pretty sure its the alarm.
Old Dec 16, 2004 | 08:50 PM
phox_mulder's Avatar
Mine works great.
No idea how they hooked it up though.
I did find out this morning that if I hit the go pedal to speed up the idle a bit, it doesn't shut off.
In reading the owners manual, I got the impression that it would shut off if the idle speed changed much.
It does shut off if I hit the brake before putting the key in though, like it's supposed to.
Can you change the voltage range? or tach range?
Oh, mine is a Viper, either a small step up or small step down from the python.
phox
Old Dec 17, 2004 | 05:29 AM
jeephauler's Avatar
When I did mine, there is a routine that the isnstructions told me to go through so that it programs or remembers the idle tach position when started. Before I programed this mine also started and then stalled out. Check your instructions to see if yours has this feature also.
Old Dec 18, 2004 | 09:45 AM
LanceD's Avatar
I did that and it didn't fix it. any other ideas?
xxwildbillxx
17
Jan 28, 2009 07:32 AM
Bigsmoke3500
Mar 19, 2008 03:51 PM
RED99CTD
42
Nov 21, 2005 02:36 PM
The Domie
Jan 24, 2005 06:08 PM
dieselnewbie
13
Mar 19, 2004 10:08 PM
