24v head on 12v?
Old Nov 14, 2007 | 07:51 PM
deereguy07's Avatar
I have a couple of friends who have built several p-pumped 24 valves. They say that they have a sound of their own.
Old Nov 15, 2007 | 11:57 AM
lgp9999's Avatar
Originally Posted by dieseldemon
The combustion chambers in the 12v is set to the ex side of the piston and the combustion chambers on the 24v is in the center of the piston therefore the 24v head has the inj in the center of the head and would miss the combustion chamber of the 12v piston and wash the walls of the cyl. of oil and score the wall.
Okay, so we would need different pistons, but I call BS on washing the oil off the cylinder wall. That happens with gassers, but diesel is an oil and HELPS lubricate the cylinder walls.
Old Nov 15, 2007 | 01:03 PM
logskidder's Avatar
They wash down, and if its cold...they really wash down. Even stock!!
Sunir's Avatar
So what be the best a p-pumped 24V or a 12V? I'd think that by having the 24V engine plus the P-pump (instead of the VP44) you'd essentially be getting the very best of both worlds, right?
Old Nov 15, 2007 | 01:13 PM
getblown5.9's Avatar
not really, the 12v has bigger stronger valves, and less moving parts, a 24v has double the chance to break a valve stem or spring, and the airflow gain is really not that significant.
Old Nov 15, 2007 | 02:08 PM
MikeR's Avatar
There's this guy in Idaho I talked to on the phone. He owns a shop called Merwin's, and says he's been doing 24v heads on 12v blocks conversions for a few years now, does all the custom injcetor lines and everything, and also specializes in Cummins conversions into other trucks (GMs, Fords). 208-704-8928
CMooreBLKSMK
22
Dec 26, 2008 11:03 PM
smokin06
26
Nov 25, 2008 10:24 PM
AnArKey
Jan 11, 2008 07:22 AM
CmminsBeast
Aug 21, 2007 07:24 PM
boostedte37
13
Mar 13, 2007 01:44 AM
