215 troubles
Old Jan 23, 2009 | 09:00 PM
DisplacedOkie's Avatar
215 troubles
Well I took out my wore out 175s and put in a set of used 215s, along with injector install kit.Now it seems weaker, pops above 2000 rpm, and runs about 10 psi lower on peak boost, was 38 now struggles to get to 30. Any ideas or might these injectors not be good?
Old Jan 24, 2009 | 12:33 PM
Lil Dog's Avatar
Seems like a fuel starvation issue or getting air into the system.. I would re-check all the connections to/from the injectors and fuel lines that were moved in the install. If the 175's worked, the 215's should perform the same.
Mostwanted
Sep 14, 2003 10:11 PM
Trickytrae
Apr 20, 2003 04:00 PM
gunracer1
Feb 18, 2003 09:10 PM
rharveysr
Jan 25, 2003 05:36 PM
gunracer1
Dec 27, 2002 11:34 PM
