1997 12v a/t trans problems towing
Old Sep 30, 2009 | 09:50 PM
drivesmopars's Avatar
97 12v only about 50 hp increase, a/t trans 4x4 dually
towing up grades with 6000 lb trailer od stops going into od
non od i run up to governator and only goes into when cooler
how do i get od or overdrive to work at a lower rpm
i lave to run to 2300 rpm and then shift
i did add a bd high pressure kit that fools the trans into thinking
iam applying more power then i am. is that the problem?
i realive a modified tork converator is a must , as it slips over
10 lbs boost , so i cant use hardly any power
this trans needs help, just dont want to go full replacement now
what items can i get replaced 1st
i can take it to a shop in sacramento ca
thanks in advance
Old Oct 1, 2009 | 08:58 AM
Cowboy_Customs's Avatar
So at what RPM does it kick out of OD? You may just need to adjust your TPS, but I wouldnt recommend stressing a basicaly stock tranny hauling in OD up hill either, so I wouldnt demand that it stays in OD. It is only going to burn it up a lot faster.
yukondg
Sep 30, 2007 07:47 PM
Redneck_King
Apr 24, 2007 07:32 PM
mysterystench
27
Oct 17, 2006 05:27 PM
Common
Competition / Pulls / OffRoad
Jul 15, 2006 02:54 PM
southernsmoker
Oct 16, 2003 02:43 PM
