1994 auto tranny lines
Old Aug 27, 2018 | 11:46 PM
dougcarlo's Avatar
While removing my tranny on my 1994, 12v, automatic, my transmission slipped off my jack stand and caught all my transmission lines. Needless to say all lines are bent. I was wonder if i can use high pressure flexible lines? Has anyone done this before? Thanks
Old Aug 28, 2018 | 02:33 PM
texasprd's Avatar
RockAuto shows replacement lines - the only thing that worries me about those is they don't show the nylon/plastic clips that go over the flares to lock them in the quick-connects on the hoses to the liquid/air cooler. I would want to replace those clips while replacing the hard lines, if possible. I think the same lines are available on PartsGeek and other places. If you google-search the manufacturer and part numbers you can probably find someone who can tell you if the clips are available. When I replaced one of my lines after it rubbed through, I cut all the quick-connect flares/ends off and went with compression-to-barb fittings for that liquid/air cooler.
Here's an interesting kit to go the route you're asking about.
Astro
Mar 9, 2010 09:03 PM
97CTD
Jul 13, 2007 12:10 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
