160 pump
Old Jan 30, 2010 | 07:06 PM
newdad's Avatar
Question 160 pump
can you squeeze 300 - 350 cc's of fuel out of one of these pumps and it still be reliable? if so, what would i have to do to flow that much fuel and how much would it cost approximately?
Old Jan 30, 2010 | 08:03 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
You could add different DV,like 181,191 or lasercuts...Just not sure how much each adds in fuel....Lasercuts for sure would add the most fuel,
Old Jan 30, 2010 | 08:24 PM
newdad's Avatar
ok so lazercuts are a must with this small pump i'd say
Old Jan 30, 2010 | 08:44 PM
Yes..The LC will fuel to the max...I have them on my 175 pump and I had to really thighten up the AFC to hold back some of the fuel...Otherwise I don't mind them....Also a zero plate in the pump would give additional max fuel..
Old Jan 30, 2010 | 08:47 PM
newdad's Avatar
thanks for the info
Old Jan 30, 2010 | 09:18 PM
No problem...Are you going with a all out race truck or pulling truck??
Old Jan 30, 2010 | 09:37 PM
newdad's Avatar
no just a sleeper 1st gen lol
Old Jan 31, 2010 | 12:16 PM
Brendan's Avatar
Are you talking about a 1st gen with a 160 VE pump? or a first gen with a swapped in P7100? Or a second truck? it would help if you filled in your signature so we could see what you have.
Old Jan 31, 2010 | 12:48 PM
rattlerbob5.9's Avatar
Exclamation
Before any max fuel i hope you have gauges and know how to read and understand them !
After the BBQ (piston melt) or blown head gasket the lack of gauges will be a very expensive lesson to have missed. Additional air and head studs, and transmission strength are a couple of others you might want to get familiar with as well prior to max fueling.
Old Jan 31, 2010 | 09:29 PM
Good point...I assumed it was a P-pump..
Old Jan 31, 2010 | 10:31 PM
newdad's Avatar
yes i was talking about a 160 p pump. thanks for the advice.
Old Jan 31, 2010 | 10:42 PM
Cool...I didn't know there was a 160 VE pump..Don't know much about 1st gen...Don't want to give bad advice...
Old Jan 31, 2010 | 11:10 PM
newdad's Avatar
ya i believe all of the ve pumps were set at 160
Old Feb 1, 2010 | 12:29 PM
sgreen3's Avatar
some ve pumps were set at 177hp and a few set at 240 but there for ag applications
Old Feb 1, 2010 | 07:00 PM
partyshortbusdr's Avatar
lazer cuts are a stupid idea
you can get 500cc out of a 160 pump
if you want to get the most out of it take it to a pump shop and have the barrels turned.
Put some .022 delivery valves in if you want more fuel that way, leave the shoulders on the delivery valves, they are there for a reason. Lazer cuts are meant for dedicated pulling trucks where fuel recovery is key and atomization is not...
