12Valve trouble codes
Old Apr 5, 2008 | 05:47 PM
KB1's Avatar
KB1
Hello, my name is Kevin. Prior to posting this question, I did a search on this
forum to see if I could find any info. So here is my question;
I recently purchased my boss's old work truck that has over 300k on it.
Yesterday the check engine light came on. I retrieved these codes....
12 , 14, and 55.
Anyone know what those codes are for? Any help would be really apreciated. I know I need a service manual for the truck but I'm having a family emergency and need to drive the truck to give help asap. Thanks in advance for any info.
Old Apr 5, 2008 | 06:07 PM
BigIron70's Avatar
Cummins Guru
How did you pull those codes and what year is your truck?
Old Apr 5, 2008 | 07:09 PM
KB1's Avatar
KB1
Its a 1995. I did the key on key off 3 times and the light started blinking. Thats the codes i got.
Old Apr 5, 2008 | 07:25 PM
Cummins Freak's Avatar
I dont think 95's do the code thing
Old Apr 6, 2008 | 09:38 AM
infidel's Avatar
I don't think 95's do the code thing
They certainly do.
Here's the procedure and chart http://dodgeram.org/tech/dsl/trouble..._DTC_codes.htm
The info in the link says this doesn't work for '97 but every one I've tried it on does. For sure it doesn't work on '98.
Old Apr 6, 2008 | 10:50 AM
infidel thats where my thought came from I own a 97 and it doesn't do it. thanks for the link though
Old Apr 10, 2008 | 01:40 AM
Kansascrewcab76's Avatar
12- battery recently disconnencted
14-MAP sensor voltage below .16V or over 4.96V
55-End of code sequence
Old Apr 10, 2008 | 08:33 AM
513yj's Avatar
don't 95's not have map sensors i haven't seen one under my hood anywhere.
Old Apr 10, 2008 | 10:50 AM
dc10freighter's Avatar
I thought the US car manafacturers had to be OBD II capable by 96. I assumed this dealt with diesel pickup trucks also. The OBD II automobiles wouldn't necessarily show trouble codes with the check engine light. That should be something up untill 96. I have never looked at my truck close enough to see if it has an OBDII diagnostic port, I just assumed it did.
The diagnostic port according to spec should be visible from the drivers side looking inside the door. It is typically on the right side around the drivers knees.
That is how I understand it anyway.
Old Apr 10, 2008 | 11:01 AM
513yj's Avatar
all computerized vehicles have a test port somewhere, my 95 has the old chrysler plug but the only thing computerized on the engine is the tps afaict. chrysler vehicles even after 96 such as my 97 intrepid have the key forward and back 3 times to check codes with check engine light. they have 2 sets of codes for the intrepid one for the mil (malfunction indicator lamp) codes such as 12,24,55, and then the obd 2 p codes with the mil code 24 and then p0107 map sensor voltage low for an example.
ridlangus123
Dec 30, 2013 08:36 PM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
3Sigma
Sep 30, 2006 10:19 PM
