12v wont start
Old Nov 28, 2011 | 01:33 PM
brapppp's Avatar
Exclamation 12v wont start
i installed 4k governor springs sat afternoon... sat evening i was driving and got on it around 2500 it popped into neutral..[when i installed the tranny i didnt adjust the shift linkage right] it reved to around 3200 and the truck shut off... as i coasted i restarted the truck but it wouldnt rev would only run about 2000rpm about half throttle..... good oil pressure no abnormal engine noise. just spuddered a bit. parked it and the motor is dry no puddles [oil][water] under the truck. i went to start it sunday and it only cranks. checked governor springs there still at correct. pulled valve covers nothing bent. cracked injecters good fuel. will start on starting fluid.. just wont run. any suggestions?
Old Dec 7, 2011 | 01:44 AM
brapppp's Avatar
40 degrees out of timing! To much rpm! Oh well were advanced now
rynojr4644
14
May 18, 2009 07:23 AM
D32C
May 17, 2009 08:57 PM
judgester
Nov 25, 2008 09:57 PM
qcstunter
Jan 9, 2007 04:10 PM
troutbum
Mar 6, 2006 03:40 PM
