12V Gas Mileage and RPM at Highway Speed
#31
I have a 97 Auto, 4x4, 4.10s, and 265s.
I get 15mpg, 15mpg in town, 15mpg on the highway, and 12-14mpg towing roughly 5-6000lbs. However I am pretty hard on it around town, and on the highway i am running near red line. I run about 80mph, running roughly 2700RPMs IIRC. Red lines right around 89-90mph. Maybe my ol' cummins is starting to get wore out at 306k, but I wish I got the mileage you guys are talking about.
#33
#34
my mpg will plummet if i cruise above 2000rpms...i like it 1700-1800 rpms...i think a big factor is overrall speed more than anything...i have heard stories of guys loosing 5th gear and riding home using 4th with comparable mpg...anythign over 65mph is gonna drop ur mpg IMHO...stories of people crusing at 75mph at 2200rpms and gettign 22mpg is
#36
Tim9712v:
If you slowed down to about 2000rpm's, your improvement in fuel mileage would surprise you.I have the same setup as you and if I set my cruise at 60mph [1800 rpm] on the interstate, I get 21 mpg.Running 65 mph towing my trailer on the interstate I get 13.5.I think I could do a little better at 60 mph but I have to keep up with my son-in-law.The right foot has a lot to do with your mileage.
#37
I rode back home from Indiana from Scheid one year with Cumminsdriver. He was curious to see what his highway mpg was so we filled it up before we left Indiana. Got about 10 miles away from home and filled it back up again. According to my precise calculations he was able to get 22.8 mpg. Most of the trip we kept it around 75mph.
#38
#39
Montana to Delaware and back with '97 4wd, 5 spd, interstates & state highways, cruising between 65 and 75 depending on the road and traffic. We averaged 21 mpg over 5,000 miles. It seems that speeds over 75 mph will drop mileage to 19 or so, keeping it at 65 gets up to 22. Last year we picked up a 34' 5th wheel, 8,500 pounds empty, and are averaging 12 to 14 mpg towing at 2,000 - 2100 rpm. I tried towing at 1700 rpm, but the engine seemed to be luggng and mileage dropped. I have 3:54 differentials, 2000 rpm is 65 mph, give or take speedometer error. No estimate for in town driving. I've never gone through a full tank in town to check it.
#40
DTR's Toad Wrangler
Call BS if you want keep it under 1300 rpm shifting at no more than 1600 you can get 11 kilometers/ liter. And if you know how to use a diesel to it's full extent then you can do this. Cummins suggest to stay at or under 1300 rpm. I can get 10 klicks/ liter consistently on #2 mixed with PS.This is truck only. And I will take on any bets for your title against mine. If you dare to call BS on this I will sell your truck for my gain.
#42
DTR's Toad Wrangler
http://www.teaching-english-in-japan...ters_per_liter
I never said 27, I'm still taking bets.
#43
At 1300 rpm,, how fast are you going? 1300 rpm on a cummins diesel in a Dodge is Lugging it. Maybe 1300- 1500 on a big rig is ok as they have alot more gears than our trucks do. There is now way you can only be running 1300 on an interstate. My Cummins dealer told me to keep it around 1800 - 2000 rpm. Also on a Stock Auto trans 1300 is way to low of a rpm and it will heat that trans and destroy it,, There is not enough line pressure at 1300 to keep the convertor from slipping, and it will chatter and warp it, and not long after that you will be buying a new transmission
With your setup 1300 means you would be going 45 mph with the stock 245/75/16 tires
#44
just idling in gear is almost 1300, lol. the 5spd would be near impossible to keep the rpms that low. And i'd think the mpg would be worse down low because most trucks with alittle power mods smoke like crazy if u bog it like that.
#45
True, I can keep it going without bogging down about 1000, but the moment you lay into it, you can tell it's dying for you to downshift. It will dump smoke like mad from those rpm's.
