12v Fuel Pressure Gauge where to add?
I assume you are asking where the best place to tap into the fuel system is? I took the banjo bolt at the inlet of the IP out and drilled and tapped it. With a 12V, you need some form of a snubber or needle valve or the gauge will go crazy on you.
Make sure to use a quality needle valve if you go that route as mine is so touchy that it is hard to adjust properly. I have mine shut off at this point because of its irregularity. Sometimes it takes a long time to come up to pressure if at all and sometimes even tightened that much it will still bounce. Could be $8 gauge I am using. But at that price if it goes bad it is not a big deal to replace it. Where is everyone getting their needle valve?
Instructions here https://www.dieseltruckresource.com/...41&postcount=9
Isspro sells a snubber that works reasonably well if you don't want to go with the needle valve. It causes your gauge to be quite slow to react but if you are using a fuel pressure gauge just to make sure that your LP is fine, it will do the trick.
dodgeguy71
17
Jan 19, 2012 12:52 AM
cj5er
0
Oct 5, 2009 08:04 PM
ITD
Oct 16, 2008 08:00 PM
dodgemaniac
Jun 12, 2007 08:21 AM
TxDiesel007
Sep 9, 2006 08:35 PM
