12 valve knock or something else??
Old Mar 10, 2018 | 12:05 PM
Huntingmatt418's Avatar
Old Mar 10, 2018 | 03:10 PM
johnh's Avatar
without hearing it in person, it sounds normar to me!
Old Mar 10, 2018 | 04:51 PM
Thanks for the reply
Hey John, thanks for the reply. It’s hard to hear sometimes In the video. You can hear it pretty good near the end when I’m down by the oil pan. It actually will get even louder when it’s running longer. I wish I knew how to work on these things.
Old Mar 12, 2018 | 09:38 AM
patdaly's Avatar
Sounds perfectly normal to me except for the bearing squeal, that will b getting worse, likely Alternator or tensioner pulley. Take the belt off and spin each to see which on is rough.
If you have good oil pressure, run it...........
Old Mar 14, 2018 | 09:57 AM
I believe the tensioner pulley is the culprit. You can hear the noise a little better In this video. The engine is warmed up to operating temps. Rod or main bearing??
Old Mar 14, 2018 | 11:08 AM
patdaly's Avatar
Do you still have good oil pressure?
I still don't hear anything bad going on.
Old Mar 14, 2018 | 12:54 PM
Hey Pat, oil pressure by the dash gauge reads around 30 psi at idle and 40 psi at speeds. I assume this is a acceptable oil pressure. I’m going to get a mechanical fuel and oil pressure gauge to verify though
Old Mar 14, 2018 | 10:40 PM
gorms's Avatar
I agree sounds pretty good based on the videos. The studder and smoke on free rev is not really anything to worry about, all about how it performs under load.
Old Mar 16, 2018 | 09:53 AM
patdaly's Avatar
Yep, verify it but that's beautiful oil pressure......... You might check the valve adjustment, but if something is bad wrong, they usually don't hold together very long, these things run at some incredible pressures.
Zee
Mar 23, 2010 09:54 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
sinwagon2500
16
Jan 10, 2004 01:34 PM
