#111(??) plate
Old Feb 25, 2005 | 09:05 PM
got...DIESEL?'s Avatar
#111(??) plate
What you say? Well while tinkering the other day, I was examining the gov contact with the plate. A little history....I started with a 0 plate and the arm wouldn't contact it, so I moved it a ways fwd to get contact, but I had to move it too far for my liking. Not wanting to try and adjust the arm in the truck, I decided to jump on the new fangled 100 plate bandwagon. So I made one up and it took a lot of fiddling with the ramp design before I got it where I liked it. Having the ramp on the bottom allowed me to move it forward some and still let the arm contact it. Any way, I was noticing yesterday that the geometry of the arm wasn't real good having to reach that far out to the plate. Kind of took it off its centerline. I wanted to come up with a plate that would bring the arm back closer to a stock position, as it would ride a plate placed in that stock position. So I took my old 0 plate and went to the mill. After seeing another members modification to a 100 plate I got an idea to make one similair but a little different. I milled into the plate at the bottom forming a ramp, much like a 10 or 100, but starting at a 0's face. I milled inward, not too deep to get to the rivets, and then brought that line straight up for about 3/8 inch. At that point I ramped back out to the 0's face gradually until I reached the top of the plate. With this plate, I can run it close to stock, leaving the arm close to stock position. Because of the deep cut in the face above the ramp, it fuels like a 100 fwd quite a ways. The ramp on top may defuel a little at high rpm when I get the 4K kit, but I'll deal with that then. The results were terrific, have all of the "felt" power and then some, a crisper off idle, and 65 mph egt's are at 600 with 5 psi boost. The 300's will smoke some under full power, so I know I am fueling good when I want it. Anyway, just food for thought on big plates in little pumps. And I will give credit to the fellow that sparked my thought, though for the life of me can't find the thread again to remember his name.....any way, thx.
Chris
Old Feb 28, 2005 | 06:41 PM
MY WORLD's Avatar
#111 plate
Chris,
I jumped on that bandwagon myself.
I put a small step at the bottom for ease of contact on the stock plate. Then, I went in to the plate about 2/3 of the way to the rivet area. Just as you did I went straight up about 2/3 of the way. From there I ran a diagonal line back to the stock top of the plate area.
I seemed to be on the right track with my first attempt as well. Now I'm anxious for the second try.
How did your plate perform?
I did that 0- 10 lbs. test. dropped to 15 mph, 3 seconds
0-60 test about 6 seconds.
brake tq test was a little quicker.
I plan one more plate as soon as I dyno this one & the #4 together.
Chris PM me about all this, if you have time.
Thanks,
Wayne
Old Feb 28, 2005 | 09:18 PM
Sounds like my plate to the tee, I love mine so far. Check out this thread as well for an interesting read....
https://www.dieseltruckresource.com/...968#post605968
I'll be PMing you
Chris
txarrowhunter
Mar 31, 2010 05:04 PM
ramtd02
17
May 4, 2008 01:59 PM
banks twinram
Feb 5, 2005 10:38 AM
