FASS Filter Change
FASS Filter Change
First question is how often do I change this thing?
Second is HOW do I change this thing? Pictures?
I had someone else put it in and now I want to know how to change it?
Tips, suggestions, thoughts.... Thanks to you all!
if you mean the fuel filter you un screw the old one fill the new one with fuel and screw it back on. the water sepp does not need changed jest drained you loosen it shake it for a few sec and let the dirt settle to the bott then loosen the plug on the bottom and let it drain till the water is gone then tighted the drain plug the tighten the water seperator back up.
pw58
12-24-2014 11:52 PM
Oilburner04
07-11-2007 08:41 AM
ollie32
06-03-2007 09:29 PM
doitl8r
06-04-2004 11:14 AM
