need help torq lockup problems
Old 10-12-2002, 02:39 PM
bear's Avatar
I'm new here so be patient with me. I have a 99', 2500, 5.9<br>24 vavle,with 67000 miles on it 47re trans. torque conv. does<br>not stay locked up, it kicks in and out between 45-60 mph.<br>I've replaced speed senc., brake switch, upper valvebody seperator plate, and had apps. senc. checked out alone with<br>doing recal. nothing has worked thus far. can anyone help?
Old 10-13-2002, 03:06 PM
bear's Avatar
Re:need help torq lockup problems
Thanks for the tip, my bat. look pretty clean though. I'll have <br>them checked for voltage.
Old 10-20-2002, 06:56 PM
dalton4's Avatar
Bear, member on the other site found his problem caused by wire noise from other wires in the same wire loom that carried the lockup signal wire. He corrected situation by removing said wire and putting it in a separate loom. Something to try if other things are checking out ok.<br><br>Good luck ...<br><br>Jerry
93dieselZak
06-16-2011 06:10 PM
JQmile
09-15-2010 10:43 PM
Cowboy_Customs
05-06-2008 09:39 AM
cjones42
02-25-2008 05:11 PM
bear
10-16-2002 10:35 PM
Quick Reply: need help torq lockup problems
