1982 Dodge CTD 5spd
Old 09-07-2011, 11:01 PM
  #46
gyman98's Avatar
After;
Old 09-08-2011, 11:20 AM
  #47
Received 1,332 Likes on 862 Posts
What are those fasteners you used on the back of the panel? They look like bolts...but do they have a different head to slip behind the fiber board panel?
Old 09-08-2011, 11:59 AM
  #48
gyman98's Avatar
They are M6x16mm wafer heads. I used machine nuts with notched washers for the inside. They worked very well in place of the factory plastic rivets. I will cut the bolt sticking past the nut with a angle grinder which will lock the nut in place. I plan on running dynamat over the inside of the panel which will stop the bolts from rattling against the door
To answer the PM's this is why the black with gray, these are the seats I'll be using:
Old 10-07-2011, 10:20 AM
  #49
gyman98's Avatar
The guy doing the body work and paint was having trouble making the panels line up on the drivers side so its going in for a frame check and adjustment if neccesary
Old 10-07-2011, 11:19 PM
  #50
gyman98's Avatar
It was out 1/2" on the front left and 1/4" on the right rear
Old 11-05-2011, 12:32 PM
  #51
LuckyCharms's Avatar
Truck looks great so far!! The guy who was supposed to do my conversion waited all summer to tell me he can't do it now....anyone know of a shop in South Western Ontario that can do this job "properly" ??
Lucky
Old 11-08-2011, 03:10 PM
  #52
gyman98's Avatar
thanks! The paint is supposed to be done at the end of the month, getting excited to work on it again
Old 11-26-2011, 05:57 PM
  #53
CE_TX's Avatar
Any updates????
Old 11-26-2011, 06:54 PM
  #54
gyman98's Avatar
Not yet, still waiting for the paint to be done
Old 12-05-2011, 10:45 AM
  #55
gyman98's Avatar
Still waiting for it to come back from the paint shop, prepped and painted a few more interior pieces though.
Old 12-06-2011, 03:52 PM
  #56
bryson711's Avatar
Are you gonna put the trim pieces up on the a pillar? I have been thinking about doin mine that way, I just did not know if it would look funny not having all the rest above the doors and along the back
Sent from my DROID2 using Tapatalk
Old 12-06-2011, 11:00 PM
  #57
gyman98's Avatar
Yes I am, I'm going to have it above the door as well to cover the headliner edge. Not sure how I'll do the rear corners yet or if I will. Also intergrating a triple guage pod into the A pillar trim
Old 12-07-2011, 07:11 AM
  #58
bryson711's Avatar
You can use the factory single cab pieces in the rear corners, the only issue I cam up with was figuring out a way to trim above the b pillar in between the doors, I will be interested in how yours turns out. Also how are you doing your headliner? Are you puttting 2 factory ones together?
Old 12-07-2011, 10:11 PM
  #59
gyman98's Avatar
Good to know about the reg cab corners, I'll look for some. I was just thinking of running a strip across the B pillar. I plan on using two headliners and folding the edge over and securing with a stainless strip and screws
Old 12-07-2011, 10:20 PM
  #60
bryson711's Avatar
You will definently have to post some picture when you get it done, I might do mine the same, I really want a headliner if I can make it look good, I think if you got a single cab headliner for the front and maybe an extended cab for the back and put them together it would work out ok, especially if ya done some trim between them, when are you expecting yours back from paint?
Quick Reply: 1982 Dodge CTD 5spd
