oem fender flares
Old 11-15-2016, 06:31 PM
neverhme's Avatar
oem fender flares
Can anyone tell me how to order the laramie oem flares?. I cannot find them online.I would prefer a kit with all the hardware. I do intend to paint them,so if they can be ordered painted all the better.
Old 11-16-2016, 02:44 PM
johnh's Avatar
google this carpartsinnovate
Fitment:
2002-2008 DODGE RAM 1500 MODELS ONLY
2003-2009 DODGE RAM 2500 / 3500 MODELS ONLY
Color & Material:
MATTE BLACK POLYPROPYLENE
Feature Style:
EURO SPORTY POCKET RIVET STYLE
Specification:
4 PIECES (2X FRONT & 2X REAR) OF FENDER FLARES
- The auction item is 100% brand new in original box.
- Made by ultra strong and light weight polypropylene.
- Comes with 4 pieces of fender flares. (2x front & 2x rear)
- Ready to be painted. Can apply any color to match your car.
- Helps to reduce spray and protects paint with fender flares.
- Protects wheel wells from mud, scratches, sand and other outer damages.
- Comes with necessary bolts, nuts and hardware for installation.
- Easy to install. Direct bolt-on without any modification. (No additional drilling is needed.)
- Gives your car a whole new EURO sporty pocket rivet look.
Old 11-28-2016, 11:09 AM
neverhme's Avatar
Looking for the OEM flares,searched a bunch with no luck, 2015 2500 4x4. Looking for smooth finish like the outdoorsman and laramie come with.Only been able to find the textured black like the powwer wagon uses.
Old 11-29-2016, 10:16 AM
johnh's Avatar
did you try the dealer?
Old 04-05-2017, 10:43 AM
neverhme's Avatar
Hears the deal with the laramie oem flares.They cannot be ordered as a set or kit,they must be purchased individual,about $900.00 . Up until 2011 mopar sold them individual but painted to match you're paint code,(would make sense on the high price),now there just primed with the high price.Mopar sells two "kits", one is rough textured,one is smooth textured.The smooth textured is NOT the laramie smooth flare. I've spent 4 months with a couple of mopar dum dum parts counter people to try and figure this out.
I purchased take off's from easyauto,a ebay seller,they are good used ready for repaint to match my ram.Getting the 3m tape off is about a 3 hour job,goof off helped after a razor blade.
There is quite a bit of chatter about the 3m tape not holding on brand new trucks.From looking at my flares there is a bit of a low spot molded in that the 3m tape sets in,then the outer edge is higher which rests against the sheet metal.I think the outer edge is molded a bit high and it's bottoming out before the 3m double sided tape makes good contact.I sanded mine down a tad before i paint,then will install new tape and put my duraflaps on at the same time.
schamran
04-17-2009 08:25 AM
Eddy Reyes
32
06-05-2007 07:36 PM
Fisherguy
04-13-2006 09:17 PM
Dodgezilla
15
10-08-2005 06:25 PM
Quick Reply: oem fender flares
