How to: Check codes, test gauges, and check hours
#61
thanks man
p 0713 came up on that wiki under the p codes as trans temp sensor voltage too high this makes sense because i cooked the fluid
so I guess I need to find where the trans temp sensor is and either install a small resistor or replace the temp sensor
Think is I did have the trans temp light go on, but, not anymore.
Wondering if this send the transmission into a limp mode or something because I just has too little resistance(voltage too high) now that a sorta overheated it, or if its just something recorded in the truck brain from the previous situation.
I guess I am willing to replace the temp sensor when I find out where it is, wondering if i screws in the side of the 48RE or if it in inside the pan.
Kinda lost for now. Trans temp is fine after a few fluid changes and filters
(my bad) been checking it with an infrared hvac thermometer (my bad)
Thank you guess for showing me the wiki code number info, greatly appreciate it.
2005 dodge laramie 3500 4 dr 4wd 5.9 stock/custom air intake only-
getting 19.8 mpg
getting 19.8 mpg
#62
getting 19.8 mpg
getting 19.8 mpg
#64
#65
Is the hour calculation on the trucks the same as tractors where an hour is wide open trottle or is the Cummins actual run time at any engine speed?
47
#66
The engine hour meter is one handy tool for a number reasons, fuel economy and engine longevity high among them.
The B50 or MTBO of a pre-2008 Cummins is 350k miles. That is based on a 30-35 mph average speed.
So, take your engine hours and divide it into total miles. If you see that you are "averaging" 27-mph or higher you will (according to my research) find that your fuel economy is at a good point (given many factors), as a low average mph points to excessive idling, and not just poor fuel economy.
High idling average means cylinder washdown (low load cool running engine versus ideal higher load, hot running engine).
The latest FORDs break out idle time from total engine time. A nice feature. Known as PTO time.
My numbers in sig.
My numbers in sig.
#68
Done...
I accidentally did this is morning turning my key over 3 times trying to let the glow plugs warm up it said done and I was like oh Edit what did i do. Glad I finally know that everything is good and "Done" is a good thing
#69
You don't have any "Glow Plugs" the fuel in your Cummins is fired only by extreme compression. You do have a grid heater in the intake to warm the air when it is cold and which helps to ignite the fuel in cold weather.
Dirk5.9
06-20-2010 12:02 PM
exwrestler
02-05-2010 09:34 AM
EdmontonCanada
10-10-2008 11:37 AM
sallyman1
08-26-2008 06:20 PM
