Disabling the remote door lock horn chirp.
I tried several times using the procedure outlined in the manual for my '06 QC auto without success. It did change my unlock procedure to unlock all doors with just one press on the remote...but what's the correct procedure to get rid of the HORN blast when I lock the doors with the remote?
I thought I also read about the horn honk/no honk procedure in the same section of the manual. I left the manual at home, so I'll have to look later for you.
HTH
Tony
HTH
Tony
hey me too! every few weeks i try it again, been doing that for months, i guess that means im crazy cuz im not doing anything different but expecting a different outcome. i have a symptom like this on a 2005 dodge caravan, except i cant disable the ring if your not buckled. must be the random disable lockout feature.
Just went out and deactivated my horn chirp ...
While standing outside the truck, press and hold the lock button for at least 4 seconds (but less than 10). While still holding the lock button, press and hold the panic button. Release both buttons together.
Worked first time for me (about the only thing that has worked right today).
Carl
Carl
Carl
Carl
Originally Posted by WEATHERBY460
i am trying to disable the horn chirp that I get on my 05 when I lock my doors using the remote....is this the procedure?
To disable horn chirp feature on 05s:
1. Enter vehicle and close all doors.
2. Fasten seat belt to cancel seatbelt chime.
3. Place key in ignition.
4. Turn ignition on, but do not start.
5. Press and hold the LOCK button on a programmed key fob.
6. Continue to hold the LOCK button, wait 4 or more seconds (not more than 10), then press and hold the UNLOCK button.
7. When a single chime is heard, release both buttons.
8. Turn ignition off, or wait 60 seconds.
Procedures for the 05 Rams should also work for 05 Caravans with the security group.
tincan
19
05-06-2007 06:53 PM
xp8103
06-02-2006 07:00 AM
Schmed
02-25-2005 08:10 AM
Carnage
32
06-06-2003 10:19 AM
