03 starts and dies unless gas pedal is pressed down
03 5.9 auto with 187k miles. It just started stalling when I start it. It will die unless you depress the accelerator a bit.Runs fine after start but will die when coasting at slow speed sometimes. I can hear the fuel pump running. I have wiggled the ignition key and nothing there. I have checked the exhaust manifold temp with a lazer thermometer and all are at 250ish except the n0 1 which is about 200F. The injectors were replaced about 10k miles ago along with new filter. Any ideas would be appreciated... thanks
Administrator/Jarhead
03 was wire guided for throttle input, if I remember correctly.
Do you have a fuel pressure gauge? When did you last replace your filter? (can't tell if you mean 10k ago or recently.)
Do you have any codes? What modifications?
jmd4993
06-22-2013 07:36 AM
I PASS GAS
16
10-08-2006 04:23 AM
Palmetto_kid
03-31-2005 02:01 PM
