Starting after cryogenic suspended animation.
What precautionary measures should be taken before starting an 06 cummins 5.9 that has been in an extended (over 2years) hibernation? 50kmiles 4 injectors replaced under factory warranty at 45k.
Check the fluids and make sure everything looks good under the hood and fire it up. Your big concern will probably be the fuel in the tank. I had a JD tractor in my garage with a bad head that was in there 2 years before I got it repaired and the diesel had turned green with algae. It was a sealed plastic tank.
47
ramlovingvet
10-14-2009 09:33 AM
Silverdiesel3
09-28-2007 10:47 PM
KwikKurt
01-30-2003 01:58 PM
