Code help...grid heater delete
Old 03-03-2008, 08:24 PM
awenthol's Avatar
I've had my grid heater delete installed for a few weeks now and the code decided to pop up today... I assumed that disconnecting the relay from the battery was all that was necessary but apparently not?? Anyone know what I need to do?? Help would be appreciated
Old 03-03-2008, 09:28 PM
carl48's Avatar
if you left the two small wires on the relay and just took the large wires off it will not set the code off , if you want to remove the relay you need to place a 14 to 20 ohm 10 watt resistor across the two small controll wires so that the ecm thinks the relay is working
Old 03-02-2009, 08:34 PM
Extreme Flight's Avatar
I left the two small wires on and 2 weeks later i have a code. Now what do i do?
Big Horn
07-18-2009 01:32 PM
Erik@LCD
83
01-24-2008 08:51 AM
DWitcher
11-07-2007 08:26 AM
CL2000
31
07-17-2007 02:25 PM
98.5POS
29
12-23-2006 11:39 AM
Quick Reply: Code help...grid heater delete
