2005 Cummins NO START
Old 03-26-2017, 11:15 AM
Noja K's Avatar
Hello! I am new to this forum and appreciate your help in advance! My story:
I have a 2005 Dodge 2500 Cummins Turbo Diesel Single Cab. I have owned the truck for about 5 months now and it runs like a top.. Until yesterday. So, started the truck in morning, ( fuel guage reading 1/2-1/4 tank), let idle for 10-20 mins, which I normally do got in it, put about 50 miles on it and shut it down. I was at an auction when I shut it down and I parked on a slight incline (so the rear of the truck was lower than the front). So, I proceeded with the auction and 4-5 hours later, got in the truck and fired up fine. I let warm up again for 5-10 min. Then tried to pull out. I had the truck in 2wd, so I obviously started spinning. No problem, put in 4wd and gave her fuel to get out. It smoked black when I got on it. I pulled up and put in park to talk with a buddy, idling there for 2 mins fine. Got back in backed up, proceeded down the driveway and when I started to accelerate, she bogged down on me and shut off. So I put it back in park and tried starting it up again, lots of cranking but it eventually started. So I proceeded to road, and same thing happened at the end of driveway. Tried starting, nothing this time. Probably a fuel filter I thought. So I ran and got a fuel filter, took old, dirty one out and put new one in. Following a YouTube video, I primed the filter by switching the key on 5 times, tried starting, still nothing. So took filter back out, and discovered no fuel to filter compartment. Then thought, maybe the truck doesn't have any fuel in it! (Even though the guage was reading 1/4-1/2 tank). So I got a rollback, loaded it up and headed to the diesel station. Put about 7-8 gal in truck. And brought it back to the house. I let the truck sit all night, and in the morning, tried to prime the filter again with the new fuel in it. Tried to start and just cranking. No start. Checked filter compartment and yet again no fuel. Any help is appreciated..
Old 03-26-2017, 10:40 PM
saggonwaggon91's Avatar
Sounds like you lost the pick-up pump in the tank
Old 04-18-2017, 04:34 PM
MadDmax87's Avatar
CR cummins
I ran into the same problem mine would run but no power and it took 10 miles to get it up to 45 mph. I limped it home from Kansas back to Denver. I put an after market carter 4600hp fuel pump and used 5/8 heater core hose as a fuel line. Its been working great thus far no more fuel issues. I found these trucks have two pump one in the tank and one one the back of the filter housing. I also ran a eff ton of injector cleaner after the install. I think mine was due to bad fuel.
jspatterson79
14
03-22-2017 01:51 PM
2005DFS
01-13-2013 06:48 PM
fred24
11-30-2007 06:59 PM
shortround
06-25-2005 10:28 AM
shortround
02-05-2005 08:40 AM
Quick Reply: 2005 Cummins NO START
