Replaced fuel pump, started fine, now no start
Hi folks-
After replacing my in tank fuel pump due to a broken return line nipple I started the truck just fine. Washed up and went to restart the truck and no crank. No error codes via ODB or turn key 3 times method. I've made sure it it REALLY in park. I have all other electronics including hearing the fuel pump running. As it was up on jacks and had blocks in front of the tires I thought it was the old "Not in park" problem. I'm going to check ALL fuses now as I don't know which one specifically could cause this> Will check back soon, THANKS in advance.
In case this happens to anyone else, I had a Viper aftermarket alarm I never use anymore. Armed and disarmed and the Ram started fine. Why it waited till the second start to enact, who can say?
The relay contact was not making when disarmed, before you exercise it.
Remove the two wires from the alarm relay for the starter circuit and re-connect the two wires back together as original.
DallasDodge2500
50
01-05-2014 02:40 PM
13ALPHA
24
05-04-2012 01:15 PM
jdddually
06-16-2011 09:18 PM
rpeltier01
15
08-03-2007 07:22 PM
