Breaker for heated seats
Old 11-07-2008, 09:03 AM
outlawscotty's Avatar
Where is the breaker located for the heating elements in the seats? Both died at the same time and I get no lights for troubleshooting.
Nevermind, I found it. That was not the problem though. I got no lights at all, and this all at once for BOTH seats.
Old 12-05-2008, 11:24 AM
Help my seat, please
Ok, now its cold. What is the white box under the console portion of the front seat? Is it a seat heater controller or something to do with this problem possibly? I can't see both seats' grids going bad at the same time. I get no lights on the switches themselves, therefore no trouble code; I've swapped the relay with a working one; I have some voltage to the switches (although I don't know the pin-out, there is a voltage present on some pins). What else is there?
Old 12-05-2008, 11:43 AM
REDNECK-WELDING's Avatar
where do you find the code from the blinking light mine is doing this and i would like to know the code. and the computer / timer is inder the center consel in the 01s, 2000 go through tthe trucks computer
Old 12-05-2008, 07:11 PM
Mountaineer's Avatar
Mine are both blinking. What do I need to do ?
Old 12-05-2008, 07:34 PM
Danavilla's Avatar
Can't swear this is applicable for your year trucks but here goes:
Dan
Old 12-05-2008, 08:37 PM
caleb keller's Avatar
mine blinkin on driver side. pass. works good. anyone found a cure?
Old 01-21-2017, 02:49 PM
Huftdaddy's Avatar
I know this is an older post but has anyone found a solution to this issue. My driver side is blinking, passenger works fine.....
Old 01-22-2017, 07:47 AM
richard's Avatar
Huftdaddy, what year is your truck? I can look through the wiring diagram and tell you what to test and where.
Old 01-22-2017, 09:22 AM
Huftdaddy's Avatar
Richard, 2002 2500 5.9L. 4x4. Thank you
I swear I entered all that info in!
Old 01-22-2017, 06:04 PM
richard's Avatar
Do your seats have high and low heat?
If the light is blinking it should either be the high or low light.
If both lights are blinking it usually means the element is shorted.
If the high is flashing the element has an open circuit.
If the low is flashing then it showing sensor out of range. or it's unplugged under the seat somewhere or a break in the wire.
Old 01-23-2017, 06:28 PM
Huftdaddy's Avatar
Thanks Richard. I actually took the bottom pad off and removed half of the leather seat cover to find a wire that broke and burned a small hole in the foam. Reconnected wire and it works as good as new!
Old 01-24-2017, 02:23 PM
richard's Avatar
Glad to be of help!
whytywythnostyle
03-16-2004 09:13 AM
Duck Hunter
10-23-2003 01:10 AM
LonCray
07-14-2003 08:03 PM
Goldenbear
06-23-2003 09:35 AM
c5r
01-22-2003 12:36 PM
Quick Reply: Breaker for heated seats
