ADding sport headlight, and fog lights ??
Adding sport headlight, and fog lights ??
Hello,
I know there have been a lot of posts about upgrading a non-sport truck to sport headlights; but it seems that some of the conversion kits are no longer offered in the threads I have read.
I have a 1999 2500, 4x4, NON-sport truck, that does not have foglights either.
I am putting my truck back together after being hit by an uninsured motorist....
Since I have to buy new headlights now, I'd like to upgrade. I would like some suggestions on what has been proven to work well and be reliable for doing this conversion.
Also, when I got the front of my truck apart, I found a couple places on the wire harness where there is dummy plug in it from the factory. Could one of these be for controlling the fog-lights? Does anybody know if the wiring is all there for controlling fog-lights on a truck that didn't have that as an option?
Thanks in advance for any and all replies.
Matt
Matt
I am not sure about the 99 but check the fuse panel to see if there is a place for a fog light fuse and is your head light switch set up for fog lights if so plug in a fuse try and run a test light to see if you get power?
Most likely the harness is there but the guts aren't in the fuse box. Mine has sport wiring to the headlights but no tabs in the high beam relay for the Sport option.
Search google for Daniel Stern Lighting. He will build you what you need to get them going.
Painless may also offer a kit IIRC..
My 99 is set up for it. Ck to see if you can easily pull out the headlight switch. This is the fog light function for on/off. If so ck the plug ends on the front where the fog lights would plug into. IIRC,I think they are wired negative meaning the switch controls the negative side, not the positive. Someone please correct me if this is wrong.
I switched out my headlights to Spyder projector lights which was an improvement over stock. These are even brighter than the 60/80 watt Flosser bulbs I had in the factory housing.
Thanks all for the replies. My switch is not the one that is also for the foglights, it does not pull out. I've driven trucks with factory fog lights so I know exactly what you are talking about.
If I get the time to hit the junkyard tomorrow, I'm going to pick up a switch with fog lights if there is one available. Then I will just do some testing to see.
On a side note, my plan is not to run factory fog lights. I'm putting a big "cow-catcher" type bumper on and will probably put a couple lights on it. I thought it would be nice to be able to control these with a factory switch in the cab instead of poking another wire through the firewall.
Thanks again.
Thanks again.
^ Yes, exactly. I have a 30" Led bar mounted to a prerunner front bumper and am wanting on-road led driving lights and to be able to hook them up using the factory fog switch.
I can tell ya, led is the way to go....holy moly...the light bar really turns things into day light! Good luck
do you think the led lightbar would be better than my setup (they are 130 watt ea)???
http://i276.photobucket.com/albums/k...6/P1010193.jpg
I would say yes. Those old KC's are sweet but quite a power draw. I was at my folks over Christmas and a guy in a Chevy with an led bar on top of his plow was heading down a side road. Looked like a sports stadium, it was lighting up the field on both sides of the road a good hundred plus yards out on either side, really white light and no hot spots or wasted light...I think the round lights look better on 2 gens, wish they made rounded ones....
Thanks for all the good input guys!! I'll probably go with Daniel sterns stuff for swapping to sport headlights.
I have some follow-up information about my trucks wiring for fog lights. I went to a couple salvage yards this weekend and looked at how factory fog lights are wired. Everything that I saw 1997 and older had wires coming right out of the factory harness. But I found 2 1999 trucks with fog lights. They had a small harness coming from both lights that connected to the main harness by a connector. It's the exact same connector I have on my truck.
So, I bought the fog light harness and the switch. I just installed the switch and it does control voltage at this connector on my truck!!! All I had to do was pop in another relay for this in the fuse box underhood.
I wont be running factory fogs, but I really like that I'll be able to control whatever lights I put up there with the factory switch!!! No additional wires going through the firewall!!
What sixlug said. Those KC daylighters draw a ton of power but it looks good and they will throw light further , just not the bright white light or flood pattern.
When I had them on my Willis Jeep the bulbs always seemed to go out.
The bumper I'm putting on has 2 spots where I can easily put some lights. 4" high and 6" wide.
I am thinking about adding a pair of these to be controlled by my fog light switch:
https://www.superbrightleds.com/more...ght/1699/#pane
Anybody have experience with this brand? The reviews look good. Also, I could use input on what beam-angle to get. I was thinking about 30-degrees.
mtdoragary
11-07-2013 08:31 AM
fjbiker86
37
12-09-2007 07:29 AM
806 Southern In
20
01-31-2004 09:50 PM
