97 weird coolant leak
Old 12-21-2016, 02:14 PM
cutthroatxxx's Avatar
OK so on my 97 every great once in awhile I will look down & see a drop of coolant on the corner of the oil pan & you can tell it came from near the account compressor.I have checked the water pump &all hoses.I think there is a o ring on the mounting block between the compredoor & engine is this correct?
Old 12-22-2016, 03:04 PM
johnh's Avatar
account compressor???? compredoor???
sorry i have no idea what you are talking about!
Old 12-28-2016, 10:29 AM
Midnite's Avatar
Are you sure it's not coming from the weep hole on the bottom of the water pump?
Old 12-31-2016, 11:25 AM
SIXSLUG's Avatar
A/C compressor is what my ADD is thinking.
Look at the front corner of the head/block union under the therm housing. That is where my head gasket is leaking....
Old 12-31-2016, 06:01 PM
johnh's Avatar
mine leaked there also, must be a weak point in the cummins
Old 12-31-2016, 11:24 PM
the head gasket was leaking or the thermostat housing?
Old 12-31-2016, 11:28 PM
I think& am hoping it's the wp I noticed the other day as soon as I started it there was cool isn't under the account Comp.I looked @ the water pump on the side pointing to the da & it is wet directly underneath it.It only happens after you start it besides that stays dry.
george7941
11-28-2009 09:28 PM
Mark Hodowanec
08-17-2009 11:56 AM
danalex
04-03-2009 08:45 PM
Common
04-09-2008 10:25 PM
popeyesides
12-06-2004 03:43 PM
Quick Reply: 97 weird coolant leak
