'02 wheels fit on '97?
I recently got a set of wheels from my cousins '02 dodge ctd. Does anyone know of any reason that they wouldn't work on my '97? I was thinking these rims would be slightly wider also. Is that the case? Thanks
Is that the OEM aluminum wheels you are referring to? If so, I knew a guy that put a set on his 94, which would be the same as your 97. The only issue was that his rear drums wouldn't fit inside those wheels perfectly, and he ended up having to machine a bit of the lip off the outside of his drums. Am not sure how much material he had to remove, but if you try to fit one of those wheels over your rear drum, it should be easy to see.
royta
08-21-2008 07:06 AM
royta
08-19-2008 10:21 PM
