valve lash ?
Old 11-11-2013, 11:07 AM
DieselNomad's Avatar
valve lash ?
just a quick question fellas? was checking the owners manual to do valve lash, and it says to put motor in TDC to check 1-2-4 IT, and 1-3-5 EX.
then says to rotate 360deg. this is my question, if you rotate the motor 360 deg from TDC will you not go right back to TDC? the diagram in the manual has the TDC AND BDC. I am sure I am missing something real simple here. I would think that 180 deg would move you from TDC to BDC,
Old 11-11-2013, 12:28 PM
torquefan's Avatar
One full turn on the crankshaft = one half turn on the camshaft. So basically, if you turn your crankshaft pulley (or flywheel, if you're using the barring tool) one full turn, it will line you up properly to set the second set of valves.
Old 11-11-2013, 12:45 PM
lovinCTD59's Avatar
What torquefan said.
You can find a nice writeup on the subject In the 'old FAQ' here on the site. My phone won't let me copy and paste the link. Sorry.
Old 11-11-2013, 01:06 PM
jrs_dodge_diesel's Avatar
Four stroke engines (gas or diesel) have to go around twice to complete all four strokes. The camshafts are geared at a 2:1 ratio to the crank to accommodate this.
Here's a link to the tech article:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Be sure to properly tighten all of the locking nuts, very important! I didn't tighten up my #5 exhaust correctly and it came loose down the road.
Old 11-11-2013, 01:45 PM
Thanks jrs , I knew it was something easy I wasn't getting. 4-stroke, how'd I miss that?? makes sense. thanks for the article, I knew there was something floating around on here bout doing it but seems to be hard to find when your looking for it.
REDNECK-WELDING
04-04-2008 06:06 PM
AKDSLDOG
06-02-2005 09:49 PM
Sgregory
03-05-2005 07:21 AM
ARAcummins
12-06-2004 09:38 AM
linetrash75
01-03-2004 07:06 PM
Quick Reply: valve lash ?
