map /Iat
Old 08-29-2013, 06:47 PM
Blob's Avatar
map /Iat
Where the %£% are these located on a 2001 ctd . I want to clean them but after looking on line Im still confused! anyone have pics of the engine and locations for them please........
2001 2500pu Lb ctd
Old 08-29-2013, 07:54 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Left side back of engine just behind fuel filter housing.
1 - sensor mounting holes
2 - o-ring
3 - iat sensor
4 - map sensor
5 - o-ring
Old 08-29-2013, 08:39 PM
redz's Avatar
map sen
ok so today i pulled out number 4 and there was nothing to clean the end was just like a brass colored opening?
Old 08-29-2013, 09:46 PM
Cummins Guru
BigIron70's Avatar
measures pressure the other temperature, be careful what you use to clean it with no chemicals just shop air. I have never seen one go bad.
Old 08-30-2013, 09:27 PM
SIXSLUG's Avatar
IAT wants electrical parts cleaner, it gets sooty.
MAP is a diaphragm that reads air pressure differential, it can go bad or wear out but usually doesn't until after a lot of miles.
pull the connector and use a deep socket on both, IIRC 1" 1/16 and 1" 1/8 are what you will need...
gocart
05-21-2007 01:16 PM
smclan
05-12-2007 12:08 AM
SuperDave4x4
09-05-2006 02:35 PM
BigBlue
15
03-28-2005 01:20 AM
Quick Reply: map /Iat
