Differential cover gasket
Old 09-12-2013, 09:23 AM
Silver R/T's Avatar
Both of differential covers are leaking on my truck. Should I replace gaskets or just put RTV in place of a gasket?
Old 09-12-2013, 09:43 AM
Fiftygrit's Avatar
Myself I would replace the gaskets, on my 06 they can be reused.
Old 09-12-2013, 10:01 AM
KATOOM's Avatar
Use Ultra Black or Ultra Grey. Both work far better than a gasket. But any silicone's ability to seal will only be as good as the surface is clean. Get ALL the oily residue off both surfaces first.
Old 09-13-2013, 08:49 AM
johnh's Avatar
also let the silicone partially set up before tightening the bolts
Old 09-13-2013, 09:48 AM
Received 2,394 Likes on 1,577 Posts
X2 on letting the stuff set up for an hour or so, THEN tighten them all the way down and fill with fluid.
Old 09-13-2013, 11:02 AM
KATOOM's Avatar
Make sure you check the directions on whatever you use..... Some silicone specifies no rest time to allow skinning and to install immediately. Also, dont forget about the bolt holes. Sometimes they can reach all the way through to the fluid and if you dont clean and silicone them too, then they can leak.
Old 09-13-2013, 11:33 AM
I install the cover immediately, I just don't tighten the bolts down the last turn or so, till I let it dry a bit.
I fill the fluid up after it cures as well.
My logic it it leaves a complete gasket everywhere rather than just tightening it all the way down and "bottoming out" the cover on the axle surface.
I used that tech. on my old '72 mud truck Dana 60 axles which I used to have the cover off at least a couple of times a year, flushing out water and mud.
I figured having a little more "cushion" of gasket would help if - more like when I "tap" my diff cover on a root, log or rut and potentially started a little leak.
Old 09-13-2013, 08:34 PM
SIXSLUG's Avatar
I use Katooms technique and have zero leakage or seepage over past 5 years.
nvr-enuf
04-08-2013 11:10 PM
upjeeper
11-06-2008 07:41 AM
mr. ed
10-31-2008 02:55 PM
Exekiel69
08-04-2008 11:43 PM
Hunter11
01-31-2007 08:56 AM
Quick Reply: Differential cover gasket
