strap kit for front yoke? W250 , need numbers
Old 04-23-2015, 09:24 AM
crossy's Avatar
the stock first gen(W250) i am fixing right now had the front driveshaft semi removed. No caps on the U-joint, and only one strap hanging in the yoke with one bolt? . QUESTION- I need a part number on a strap kit (Spicer?, Dorman?) for the FRONT yoke with proper 1/4-28 bolts. The bolts are not as important as the straps being correct for the D60. I have no caps to measure, but it appears the front yoke used 1-1/16" caps? ALSo ,If you have it, go ahead and give me a part number on a front u-joint also. thanx , crossy
Old 04-23-2015, 11:41 AM
Philip's Avatar
The Dorman kits you want to pass on. Go spicer only.
I have boughten three or four dorman kits. The only thing worth using was the bolts. The caps came no where close to fitting the u-joints properly.
I don't remember the number for the spicer kits.
Old 04-23-2015, 08:02 PM
crossy's Avatar
OK, thanx Phillip.ANYONE got that spicer number.?
Old 04-23-2015, 08:34 PM
Philip's Avatar
Look these over. The MFG part number is included on the page also.
http://www.summitracing.com/parts/sd...-28x/overview/
Old 04-23-2015, 09:25 PM
crossy's Avatar
3-70-28x is what i got, thanx,crossy
Old 04-27-2015, 11:46 AM
HRDROKN's Avatar
Should be a 7260 series u-joint ... also known as "small dodge". The caps are actually 1.078".
The correct strap is http://www.summitracing.com/parts/dcc-4120468/overview/
Old 04-28-2015, 04:43 AM
crossy's Avatar
well, here is what I can tell anyone searching so far - the spicer 3-70-28X is WRONG.
The moog U-joints # 534G & #316 are WRONG- and those two U-joints, even though they carry different numbers- appear identical in every way.??
I THINK THE FRONT STRAP KIT IS a Neapco 1-0023.
I THINK the U-joint is a moog 317 ??
Old 04-28-2015, 09:54 AM
HRDROKN's Avatar
Not sure what those numbers are and may be saying the same thing.... I was just doing this 2 weeks ago. The correct front u-joint is 7260 series!
Inside Lock U-Joints by Series
Old 04-28-2015, 11:41 AM
HRDROKN's Avatar
Looked up the Moog 317 and it is the same as a 7260 series!
317/detroit 7260 u-joint
broncobilly
05-21-2013 09:48 PM
Firstgenfanatic
10-14-2010 07:55 PM
bgilbert
08-22-2009 09:06 AM
dieselcarpenter
09-18-2007 06:01 PM
Quick Reply: strap kit for front yoke? W250 , need numbers
