How long does your oil stay clean?
Old 05-17-2016, 10:20 AM
feets's Avatar
Do any of you guys have oil that stays clean for more than 30 seconds? If so, what's your secret?
Old 05-17-2016, 10:35 AM
Received 2,392 Likes on 1,576 Posts
Dead stock motors have the oil stay clean looking for longer.
Turned up pumps on these motors make the oil turn black very quickly.
Old 05-17-2016, 11:22 AM
feets's Avatar
I put a bit of a turn on the pump but that's it. It'll put out a bit of a haze but does not smoke heavily under WOT.
Old 05-17-2016, 12:10 PM
jimbo486's Avatar
Any diesel's oil won't stay clean for long. There is still some amount of combustion gasses that find their way passed the piston rings.
Old 05-17-2016, 04:41 PM
Received 1,332 Likes on 862 Posts
My 93 motor stays pretty clean with almost all stock IP settings. Can go 3-4K miles before it really starts to even turn a chocolate brown.
My old 89 motor would turn the oil black in about a 1000 miles.
Old 05-17-2016, 07:38 PM
Rickcher's Avatar
Anybody use synthetic? It stays clean in my gas engines but I've never tried it in the diesels.
Old 05-17-2016, 07:48 PM
loudhornsrule's Avatar
Mine is like Tcows Stays clean 3-4000 miles then might go black. Not turned up and Rotella oil
Old 05-17-2016, 09:22 PM
sdseva's Avatar
mine pretty much goes black right away.
Old 05-17-2016, 09:59 PM
MrFusion's Avatar
Mine's been in there a year and looks like new.
Only put about 5 miles on her tho!
The oil in the 1995 CTD I had got filthy looking pretty quick.
I did a fair amount of research on oil for the CTD a while back. Lots of anecdotal evidence. Not a whole lot of physical or empirical evidence. One of the things that I found was that, due to the govt mandated ULSD, diesel engine oil has been reformulated because current diesel fuel is less "dirty". I can't recall the exact chain of research but its out there.
I am a dyed in the wool Pennzoil fan due to empirical evidence. I saw the inside of 70k-80k 440 motors that were run exclusively on Pennzoil and were SUPER clean. You could still see the paint on the heads under the valve covers. Pennzoil 15W40 is a bit hard to come by around here.
I ran Rotella in my 95 CTD and was generally happy with it however my current research seemed to indicate that the new Rotella is not so well formulated for the Cummins 12V. It did indicate that Valvoline Blue was well formulated for the 12V Cummins. Valvoline Blue is recommended by Cummins and meets all of their specs. Seems decent but I have no long term experience with it.
Old 05-18-2016, 07:19 AM
Jim Lane's Avatar
About 10 minuets.
It is the soot from the combustion process,
Your compression ratio 17.5:1 is almost double that of a gas engine.
The nice thing about choosing oil for a Detroit Diesel is it is never in the engine long enough to get black
Old 05-18-2016, 08:17 AM
kensmachine's Avatar
if you want to keep your oil clean put an oil centrifuge on it. At one time I worked for a place that sold and serviced spinner II centrifuges. Spinner IIŽ Products : High-efficiency lube oil filtration for heavy-duty diesel engines. they do work but are not cheap. Some very large engines this is all the use for a lube oil filter. there are copies made in china at about 1/3 the price but a neighbour bought 2 and I had to make bearings for both of them. WVO Centrifuge | PA Biodiesel Supply
Old 05-18-2016, 04:12 PM
jimbo486's Avatar
If it ain't leakin', it's empty.
Old 05-18-2016, 05:07 PM
gyman98's Avatar
My old skidsteer had a 4bt cummins in it and had 10,400hrs on it when I sold it. I would change oil about every 200hrs and it was always honey coloured.
Old 05-18-2016, 09:01 PM
peckens's Avatar
My 03 would stay clean between changes 6k with T6. My 93 is black as soon as I start the engine, again T6. Trying seafoam in the oil for the last 500 miles of my oil change to see if that helps
Old 05-18-2016, 09:57 PM
Jim Lane's Avatar
The old GMC transit coaches I used to work on would slobber out 5 gallons of Delo per 10 hour shift, they had 6-71 Detroit's with over one million miles on them.
Quick Reply: How long does your oil stay clean?
