Have question about ECM and the OEM #
Well i finally figured out what was wrong with the 93 that i got, Bad ECM. I swapped the one in the truck with a know good working one, and sure enough, i got charging back, AC back and OD back. So now i am searching for a new or reman ECM but the sites that i look at have a few different options for a 93 ecm with an auto trans. Each one has a different OEM #. What is this OEM # and where can i find the OEM number so i get the right one, Thanks
1st Generation Admin
Single Board Engine Controllers (Power Control Module)
P/N 5602 6858 1993, Man. Trans., w/o RFI
P/N 5602 6859 1993, Man. Trans., RFI
P/N 5602 6860 1993, Auto. Trans., w/o RFI
P/N 5602 6861 1993, Auto. Trans., RFI
I don't know what "RFI" is.
Hope this helps.
- > The part numbers may have been superseded.
Hope this helps.
I just put a ecu on my 93,I got it on the web from a place called ecu direct.I was very happy with it,it is a rebuilt,but looks brand new,inside and out. They way it looks,they must replace every thing.I had one froma place called cardones,it never worked right,and I sent it back,and they gave me another one it lasted about six months.They had a lower price,I guess you get what you pay for
I found the OEM number, it is B56029103, does this number look right, i have not been able to find a 9103, only a 9102. It was under the case, under the appoxy lower right hand side if you have the plug for the wiring harness facing you. Thanks
MY auto ecm is a 56029103 and my m/t is 56029101. a m/t ecm will not give you o/d on a a/t. hope this helps there may be many more # than we have.
Just looked on my truck and it has the 56026860, LOL!!!
TOMMY
TOMMY
Part number 56029103 was superceded by part number 4746568.
SKATERHAULER
10-02-2013 06:34 AM
BAJA MAN
11-21-2006 05:49 PM
Ohio Joe
07-12-2004 12:13 PM
