Getting hot on highway
Not sure why I didnt make the connection but today I realized that the truck only gets hot when using A/C. I guess I've been using the a/c so much lately I didnt notice. This morning it was 62 on the way into work and the temp was staying right in the middle with no issues. I kicked on the defrost and almost instantly it started to rise. I turned off the a/c and it slowly went back to normal over the next mile. So could this still be a clutch fan issue?
Air flow problems, from any cause, will increase the effect.
well it seems its the fan clutch. I pushed it today with 4500lbs in tow to see where it would run. When it reaches halfway between the third and fourth lines (inside normal range) the fan kicks in then cools it to the third line. It has no issue doing this at any speed, with or without a/c on. So it seems that everything is working ok, just that the fan clutch comes on too late.
On another note, the weight of the tow is only one factor. Grades, and wind resistance, and speed play big parts.
With very good cooling, that is a Mishmoto HP radiator, fan cooled transmission cooler, and all in good shape, I can pull a 12,000 lb park model camper at speed (70) in hot weather (85°) against a head wind (25) with the AC on and it'll run about 190° water temp and the fan clutch won't engage. Pulling an 8000 lb fiver up East Homestake Pass at full throttle third gear, she'll run about 220° with the fan screaming. All of this is perfectly normal.
M Penwald
14
03-26-2011 08:41 PM
Strjock81
16
12-12-2007 09:53 AM
duallydave
08-07-2005 09:38 PM
