Getrag 360
Getrag 360
I have a 92 d350 dually with getrag and it has a vibration and leaking oil. The main shaft has a good bit out play up and down. I took transmission out and it seems like it doesn't have enough shims? Bearings feel real good. It has 95,000 miles on it. What thickness of shims should it have? Should it have any play? This is my first time working on one.
Here's the getrag rebuild manual http://www.dieselhub.com/PDF/Getrag-G360-manual.pdf
On page 21-71 it talks about the shims. You want 0.006 - 0.008" of preload with your shims. You'll need a depth micrometer to do it properly.
I would tear it down for a full rebuild...since you already have to tear it partly apart to try and band aid fix the end play. New bearings, and syncros at a minimum.
mknittle (05-22-2016)
Once the end play is set, it should stay that way. If the end play increases you have bigger problem internally. My guess is that the bearing(s) are going bad. Even though they "feel" fine, doesn't mean they are.
TexasBlake
02-23-2004 01:26 PM
